Parking brake is sticking in cold weather. What causes this, and how do I fix it?
thru the wheel opening. Make sure the ebrake is released before using the lever. There is supposedly a updated cable to fix this, I have not yet confirmed that though.
how do you do this? Where do you look to see if the Ebrake is engaged and how do you release it manually thru the wheel?
The cable pulls the actuating arm toward the front of the car to apply the ebrake. So, first having released the ebrake handle inside the car, you position the wooden stick through the wheel so that you can lever the actuating arm toward the back of the car. It will move about 1/2" or less, and you will be able to see it move back to the released position. It does not take much force to release the ebrake this way, so you won't need to heave-ho on the lever. For reference, compare the relative position of the ebrake arm on the other wheel.
S4intheOC
09-08-2015 12:12 AM
DannyG123US
09-07-2015 05:53 PM
stormchaser1967
09-02-2015 09:26 AM
