passenger dipped headlight
as we all know this issue is huge on audi, My passenger side comes on perfect when turned on but as you brake hard, accelate hard or turn hard it flickers and even sometimes goes out. I replaced ballast, no luck, i replace bulb, no luck, i replaced wire going from ballast to bulb, no luck. Would this module actually fix it? and is this the right on for my 04 a4 with xenon headlights http://cgi.ebay.com/ebaymotors/AUDI-...ht_1633wt_1167
is it a flicker or is the autolevel motor broken or out of alignment?
if it is a flicker, i read that it can be a wire rubbing somewhere above the ballast. I have it on my driver's side, mostly on wet days. search more on AW, AZ and QW and you will see some reports of intermittent short that causes the flicker.
i have no idea about the part you reference.
DaveyKid
04-12-2004 03:58 PM
