Problem with vacuum lines?
Searched... didn't find anything with these symptoms.
Symptoms:
1. Power lacking at mid/high rpms (3000+)
2. Hissing sound at these rpms
3. Engine seems not to run smoothly under medium/hard acceleration.
Car: 2002 A4 1.8TQM, APR chip, 75k miles
Any thoughts?
Symptoms:
Any thoughts?
The CEL hasn't come on, but I'm going to run a VAG-COM check tonight.
In the past, when 2 of the coils failed, there was no hissing sound, which is why I suspect an air line is leaking.
Also, make sure your TIP is seated on the turbo tightly, as that would create the "hissing noise". Generally if the vacuum hose has ripped completely, the car will be undrivable b/c it will not be able to hold the idle RPMs and the car will just stall.
