'Quattro' badge on S4 grill?
Just installed an S4 grill on my B6. Can't get the Quattro badge to fit but I've seen them on the forum. How do you get it to fit? It seems tight.
AudiWorld Expert
...so you would need to see if you can remove enough of the back of the Quattro badge to sit flush enough to secure the clips, or remove some of the grille's vertical slats to accept the Quattro badge.
just the rear part near each side of the badge that goes up against the slats need to be made thinner. I used 2 black zip ties thru the rear badge support (usually where clips go) and around the grille slats to hold it in place. you can't tell unless you look at it close up.
if you trim grille, its not good for resale value.
JCJiffy
08-24-2000 08:50 PM
