Quattrorocket!!!! Need your expertise....? inside....
Which white wire was the remote turn on? There are 2 white wires in the wiring harness into the stock amp....a thick wire and a thin wire...
If i had to guess, i would say the thin one...but when you assume....
I figured out the wire colors that lead to the sub...i am a little color blind...so the wife helped out there.
Thanks for the help!!!!!
Patrick
Patrick
Great timing, just got in and got online !
I forget is the short answer to your quesion. Do you not have a 12volt test light or multimeter? If not get a test light. You simply ground one end and push the pointed end in to a wire. If the blub in the tester lights up there is 12v if not then nothing ! Very handy device !
Just remember that ignition turn on is a 4volt signal so the light will be weak but it will light up.
In the mean time I will go and look in about an hour. I have a bad ankle and need to ice it for a but then I will go down to the garage and check for you !
where did you get your power from for the amp? It looks tougher to get the knee bolster out of the way than my 00. Also, i though of bringing power from the battery through the rubber grommets that are in front of the glovebox, but it is A LOT tougher to dissamble the glovebox than my 00. Thanks for any insight. Oh, my meter is mucking up, who knows...murphy's law????
Patrick
p.s. anyone in need of a bently cd for an 00 A4/S4? Would trade for an 02!
Patrick
XcellR8edAudi
07-01-2004 10:26 AM
UrSoccer_mobileĀ®
18
11-16-2003 06:52 PM
benk
07-20-2003 06:03 PM
poopeter-el sigthief
12-26-2002 10:15 AM
