Question about adjusting pedals- can they be adjusted to an even distance?
I want to be able to heel/toe properly, but my clutch, brake and throttle pedals are all at different levels compared to each other. My clutch is closest, with the brake and then the throttle being farther back. Adjusting the clutch isn't that big of a priority compared to the brake/throttle. I'd like to even those two up, so I can rock my foot across both pedals properly. Anyone have any suggestions?
AFAIK you can't adjust, aftermarket pedals help...
especially the ones you drill into your stock pedals because then you can place the pedals closer to each other. I just got TT-style pedals, the gas/brake are not closer together but by no way is it ideal. You can check out pics in my pic poster.
The Brake pedal can be lowered.
I do find the brake pedal too high for heel and toe movement. I have it lowered for an inch by a tuner.He adjusted some screw just next to the pedal and it works great now!
hellonwheels33
32
04-16-2023 07:32 AM
ECS Tuning-Audi
Q5/SQ5 MKI (8R) Discussion
11
02-24-2023 12:58 AM
Monsoonenough
S4 (B8 Platform) Discussion
10-03-2015 02:59 PM
S4intheOC
09-08-2015 12:12 AM
