QUESTION: Deep circular grooves in brake discs - unsafe? (not my car - don't worry)...
I went w/a friend of mine to fill up his tires w/air the other day ('93 Taurus), and I noticed that his front brake discs had deep circular grooves dug into them (probably about 1 cm wide and several mm deep). This, I am sure, is not normal (and I'm guessing not safe either). I told him he needs to get this checked out ASAP, but what specifically should I tell him is the problem?
I dunno.. grooves don't necessarily mean the rotors are shot.
Just means there is odd wear. When you brake hard, are the brakes chattering? If so, then yes replace the rotors (or at least get them turned.) But if they doesn't appear to be any loss of braking power, then you are probably fine.
yes, but I'm saying that aren't necessarily bad.
Unless there's a serious problem such as loss of braking power or chatting, I would think its fine.
Assuming there's no mechanical problems with the brakes, I would just wait until it was time to get new brake pads and just get the new rotors at the same time. The best time to change rotors is when you are changing pads and flushing the brakes.
Albatrossboss
12-03-2015 01:08 PM
ECS Tuning-Audi
08-31-2015 01:22 PM
ECS Tuning-Audi
08-31-2015 01:12 PM
