Question on rotary headlight switch.....
I don't own a 2002 A4 yet but I believe you turn the rotary switch to low beam, pull out once to activate front fog lights, pull out again to activate rear fog light.
My question is....is it mistakenly easy to pull the switch to where the rear fog light is on and you're driving around all night looking *** end silly with one bright light that looks like a stuck on brake light and attracting the cops?
If so, I guess the answer is to pull the rear fog light bulb permanetly!
Really presents no problem at all.
In addition to the pull-out's very definite detents (it takes definite intent on the driver's part to pull out to the front fogs and then pull farther out for the rear fog), the rotary switch's front and rear fog icons on the switch light up when each is activated. The rear fog's light is amber when lit, so there's no mistaking if you have it on or off.
...really thick fog, you've learned how to not drive too close to the car in front of you while also not letting them disappear into the fog. The rear light permits more safe distance between you and the other car.
I'm modding it so there are two rear fog lights (as long as the European setup is still there).
smcg3
12
03-31-2008 08:07 AM
Me_and_my_GT
11-04-2004 08:25 PM
