Rattling noise front left insanity
Greetings all,
I had to start another account because my gmail somehow is not a valid mailbox so this is "Mark O" AKA "Slowpokee". Any how, there is a rattling noise that I am somehow unable to fix on my mothers car. Her mechanic said it was the CV joint to which I didn't believe as the noise didn't really sound or feel like a loose CV joint. I replaced the axle and sure enough the rattle is still there. Upon further inspection, the bushings on the upper and lower control arms looked pretty bad so I replaced both upper & lower control arms, tie rod end and sway bar bushings. The noise is still there. I read in some other threads this rattle could be from the break calipers so I checked and the spring is not missing and the bolts are all tight. My last task is to replace the struts. Usually a worn strut will just affect the rebound and cause the car to bounce not rattle.
Before I drop another $300 has anyone experienced a worn strut that causes a rattling sound?
Best Regards,
Mark O
Best Regards,
Mark O
Good call. My bushing kit's sway bar links had a defect with incorrect thread directions and I re-used the old links. This makes sense if that part was the culprite!
eldoj
17
08-25-2008 04:00 PM
jps17
01-04-2008 11:08 AM
jazz215
06-16-2006 09:54 AM
