RCA input into stock headunit ???
trying to put Sirius radio input into stock headunit ... is there a way to feed an RCA input ??
any links to info on adding XM/Siruis radio into the stock system ?
Sound is great.
Blitzsafe does carry the adapter but you have to order it directly from them. I was quoted $108 (includes shipping) from the sales person on the phone.
Try the FM Modulator route and if it sounds bad to you then buy the Blitzsafe adaptor. The only drawback to this is that you have to buy the two antenna adaptors to hook up the FM Modulator (total cost around $30).
<img src="http://mywebpages.comcast.net/dstech/images/Sirius/sirius.JPG">
<img src="http://mywebpages.comcast.net/dstech/images/Sirius/sirius3.JPG">
<img src="http://mywebpages.comcast.net/dstech/images/Sirius/cluster_sirius.jpg"><ul><li><a href="https://forums.audiworld.com/a4gen2/msgs/281069.phtml">Link to my original post.</a></li></ul>
From deck the RCA's run into a line level convertor to bump the signal and then to the amp. Took a while to remove the pins on the stock wiring harness but not a difficult job at all.
