re installing factory head unit
alright i really didnt like the head unit in the car when i bought it and wanted to go back to a stock look.
all the harnesses are there still and ive plugged them all in and have gotten no response from the radio. is there anything i need to do special? something that might need to be checked i dont know?? any help would be appreciated thanks
I did the same thing, but I don't remember if it has a fuse or not. Other than that it would be hard to pinpoint the problem depending on how previous wiring was done. You should probably also check the amp and make sure that is still wired in. I had to completely bypass the amp to get my aftermarket head unit to work.
Is it the unit that was originally in the car. If not then the radio code may not match what VAG think's it is. Not sure if that would stop a unit from turning on though.
the ECU set up to recognize the headunit (different security code). Also all new cars come with the headunits in "transport mode" so maybe your new headunit is in this mode and needs to be taken out of it so it can work?
Just throwing out some ideas.
xkahn
02-08-2018 10:43 AM
winter
09-07-2016 04:38 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
