READ: Installed new NGK BKR6E spark plugs
install was very straightforward and easy, took maybe 30 minutes, but only because i'm slow and methodical.
I found the plugs at O'Reilly here in Houston.
Prior to the new plugs, i had a misfire/hesitation between 2600-3000 rpm under high load and moderate to full throttle. this is GONE. i managed to get a SLIGHT hiccup but only in 5th at like 40 mph under WOT.
Car seems to run much smoother/stronger in the upper RPM's.
Best 6 bucks you can spend on your car!
