Rear Left Brake Light out....what size bulb and how easy/difficult to change?
Just open the trunk and look for a little round cover that needs to be pryed open with a screw driver. Then using a philips head screw driver remove the screw completely. Then pull the tail light from the car by putting your fingers on the trunk side of the tail light and swing it out towards the outside of the car and it should pop right out.
You can disconnect the connector if you want to remove the tail lamp assembly from the car or you can just undo the two plastic clips holding the black backing onto the tail lamp housing. It's probably easier to take the tail lamp off the connector. The brake light bulb is either the bottom left or bottom right bulb when looking at the back of the car....can't remember which one.
Keep in mind the 7528 for the "Stop Light" was replaced with the 7506. At least that's what Autozone's computer said. ![Wink](https://www.audiworld.com/forums/images/smilies/wink.gif)
2002-2004 AUDI A4 (With HID (high intensity discharge) headlamps)
Low beam headlamp
HID-D1S
High beam headlamp
H7
H7ST Silverstar High Performance Lighting: the whitest and brightest Halogen
H7CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
H7LL Long Life Halogen: Lasts two and a half times longer
Parking light
3457ALL
3457AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
Front turn signal
2827
3457ALL
Rear turn signal
7506
7506LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light
7528
Stop light
7528
High mount stop light
%COM
Fog/Driving light
H11-55W
License plate
6418
Back up light
7506
Front sidemarker
3457ALL
Rear sidemarker
7528
Glove box
2825
Map light
64111
Dome light
6411
Step/Courtesy light
2825
Trunk/Cargo area
6418
Under hood light
6411
Daytime running lights
2825<ul><li><a href="http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/LampReplacementGuide/">http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/LampReplacementGuide/</a></li></ul>
Low beam headlamp
HID-D1S
High beam headlamp
H7
Parking light
3457ALL
Front turn signal
2827
3457ALL
Rear turn signal
7506
Tail light
7528
Stop light
7528
%COM
Fog/Driving light
H11-55W
License plate
6418
Back up light
7506
Front sidemarker
3457ALL
Rear sidemarker
7528
Glove box
2825
Map light
64111
Dome light
6411
Step/Courtesy light
2825
Trunk/Cargo area
6418
Under hood light
6411
I'm handier than 90% of Anerican men and in trying to change the left rear fog bulb on my now 10 y/o A6, I cracked the lens. So my $6 bulb job will now cost $138. Audi's "too smart by half," "let Germany show how smart their engineers are" (vs Japan which does everything as well, more simply) one-bolt design does not allow the side-most part of the lens to release. Because Audi decided to hide bolts IN THE TRUNK! My wife's Honda had two screws visible in the trunk and I changed THAT bulb (9 years after it was new) in 1 minute. This is why my next car is an Accord that costs less to maintain, holds it value better and is far more simple to live with.
PS. I don't think I've ever actually used the rear fog lights but the bulb went anyway, causing the annoying dash warning light to come on. Thanks Audi!
