replace plastic temporary lug bolt with metal?
what is the easiest way to get/make a bolt (no shoulders, natch) that i can use when changing wheels, instead of the POS plastic bolt that stripped the first time i used it?
Are you talking about the plastic bolt *COVERS* that come on the wheels? You remove those first (m)
using the bolt cover puller in the spare tire tool kit. They don't unbolt - the normal lugs underneath them do.
...or were you referring to something else?
clarification - see within..
the jack kit includes a 4 inch plastic bolt that you thread into the top hole in the brake disc, before removing the other 4 bolts, and the wheel. you leave it in place as something to hang the replacement wheel on, then install the other bolts loosely, remove the plastic one, and then tighten all 5 to spec.
but the plastic bolt strips easily :-{ - or at least it did for this ham-handed person.
Convert to studs from ECS
<center><img src="http://www.ecstuning.com/HR/images/products/studconversion-large.jpg"></center><p><ul><li><a href="http://www.ecstuning.com/HR/product/HR/studconversions.html">ECS stud conversion</a></li></ul>
just need to find out the thread pattern or dimensions and have a bolt threaded.
my father is a plumber and he has a machine that can do this and he is going to be doing this for me but he just needs the specs.
N'Syncro
33
02-16-2020 03:12 PM
rayjr13
10
04-12-2016 04:43 PM
cm09578
09-22-2015 06:38 AM
wolfcj
09-03-2015 11:56 AM
