Replaced my fuel filter the other day...
jack up rear end, remove 4 nuts holding plastic shield on, remove 1 torx screw holding the filter in place, and disconnect the 2 lines going in each end. One hint though is to make sure you depress the tabs on the plastic connectors fully before trying to remove them from the filter else you'll break one like I did =P
watch your eyes and make sure you are away from fire or sparks. smoking while trying to get the filter out is probably a bad idea
