Replacing injectors- thoughts?
I was just wondering what people thought about upgrading injectors. My car is Upsolute chipped and it's mapped for stock injectors but I was wondering if it would do any harm to upgrade to the APR 1+ sized ones. Theoretically, even at the same ignition timing and boost levels it should provide better performance, right? Are they plug and play with the current ECU? Any pointers would be helpful.
Thanks,
Dave
Thanks,
Dave
Bigger injectors utilizes the programs that are designed to release the fuel at shorter interval as opposed to the programming for stock injectors. Therefore, the fuel curve is different.
If you run the car with the current setup, it'll run rich. The ECU will assume x amount of fuel and h amout of air when really you'll be putting in x+ amount of fuel and the same h amount of air. Eventually it'll throw a code because your O2 sensors won't know what to do. If you spend the money to upgrade to bigger injectors, you might as well spend the money on the new chip so that you can get the most out of them.
...compensate for the extra fuel by cutting the injection time - but only within about +/- 9%. Over or under that and you'll get a CEL. You'd have to increase flow with a bigger turbo to get any additional benefit over stock and that would primarily show up in the upper RPM ranges. There are some adaptation channels you could play with to increase fuel on acceleration and at higher RPM's but it's not for those without the proper test equipment.
Mark VII
14
09-26-2023 10:11 AM
McFuzz
A4 (B8 Platform) Discussion
09-17-2015 07:11 AM
ZPA117
09-08-2015 11:55 AM
anticsAK
09-04-2015 09:59 PM
ECS Tuning-Audi
09-03-2015 12:45 PM
