Road Noise
Hi all, I need a little help/advice. I have a 2003 Audi A4 1.8T Quattro with 60k miles that I'm getting a lot of road noise from. For a while I thought it was noisy tires because I do need an alignment, but now I'm thinking it's something else. I sounds like it's coming from the front left side of the car. The sound is a rumble at low speeds, tire noise, but much louder at higher speeds. I had an 89' VW golf that had a bad front wheel bearing, but I thought I remembered that being even louder, but the sound is similar. Any ideas, what could it be? If it is a wheel bearing, what is the normal cost of parts and labor? Should I replace only the bad one or both fronts or all four?
thanks. is that to replace just one? any idea if it's best to do 1, pair, all four? i searched for the cost of the bearings, it looked like $100 for the front pair, $150 for the back. does that sound about right?
Audi replaced it under warranty. That's why I don't have a price for you.
Minimarvel
08-04-2016 04:37 AM
Jiggie
09-26-2015 09:49 PM
changareth
09-25-2015 11:27 AM
