Service!
Old 05-11-2006, 05:08 AM
DZA
DZA's Avatar
Default Service!
Why would my car still say, "Service!" when i press the wrench button next to the check button?
Will it say service for trivial things like 3 alarm trouble codes and the fact that my rear fog light is out (doesn't even exist but i have a trouble code for it). I also have a headlight/taillight warning light on but the lights are all on and fine.
There are no important trouble codes.
Old 05-11-2006, 05:14 AM
Jimax's Avatar
Default No, it means the light wasn't reset the last time your car was serviced.
It's a simple procedure to reset the light. Something about holding two buttons down with the key in the "on" position.
It's in the manual. It's simple to reset the light.
That light does nothing more than count down every 10K miles. When you reset it, you have 10K miles before it'll bug you again.
Senior Member
a4tis™[Bye Turbo]'s Avatar
it needs to be reset
Old 05-11-2006, 05:19 AM
DZA
DZA's Avatar
Default Re: it needs to be reset
the codes were reset... what else and how do i reset it?
Old 05-11-2006, 05:20 AM
DZA
DZA's Avatar
Default Re: No, it means the light wasn't reset the last time your car was serviced.
so that freeking thing isn't connected to anything but a 10k trip? the heck? lol
Old 05-11-2006, 05:21 AM
Rest In Peace
All Wheel Driver's Avatar
Default My service reminder doesn't work. It has dashes, even after being reset. Can I fix that?>
Or is that a malfunction that will require the dealer to check out?
I'm guessing it's not normal and something is wrong with it.
Old 05-11-2006, 05:23 AM
Senior Member
not the codes, you need to reset the service interval indicator...see Jimax's post below
Old 05-11-2006, 05:27 AM
Jimax's Avatar
For the first 500 miles or so, it will be all dashes. Check after 500 miles, it will be normal.
Old 05-11-2006, 05:28 AM
Jimax's Avatar
You got it, a fancy trip odometer is all it is really.
Old 05-11-2006, 05:30 AM
Jimax's Avatar
Default Here's the reset procedure
<ul><li><a href="https://forums.audiworld.com/a4gen2/msgs/904377.phtml">reset</a></li></ul>
Quick Reply: Service!
