Significant digits in part numbers
How important is the 10th digit in part numbers?
I need to replace CD/radio and A/C control unit because a guy in a garage spilled coffee all over them causing a short in both.
I've been searching for used parts and sometimes I find parts that look identical, but their numbers differ by the last digit. For example my radio is 8E0 035 195 A, but I found a radio with 8E0 035 195 F. Will this be OK?
Sorry if this question has been answered before, but couldn't find an answer through search of this forum...
Re: Significant digits in part numbers
I called a dealer and he told me that the part number has to match exactly or differ by the last "X".
So if I have 8E0 035 195 A, the only other number that would be acceptable is 8E0 035 195 AX. As I mentioned, I found something with an "F" at the end.
Is he telling the truth or he would rather have me buy a new part from him?
The "X" tacked on to A, means the part is a reman exchange. ...
The PN I found is 8E0 057 195 F and is listed as a Symphony II for B6. The 035/057 is typically differennt manufacturer. If the Radio came out of a B6 A4, it will fitt your A4 no problem. for what it's worth, the dealers's reman exchange should only be a couple hundred with your A unit, and will have a warranty. If you get the F, be sure to get the security code that goes with it.
milellie111
19
10-17-2020 07:38 PM
Dr Chill
S6 (C7 Platform) Discussion
11-05-2015 09:25 PM
FedericoDC
2.0T FSI Discussion
09-05-2015 11:45 AM
change2E85
09-05-2015 09:07 AM
