so is it possible...
to swap out bixenon housings with my 2002 xenon housings?
or better yet is it worth it? is there any difference in the light pattern from the bixenon low beam bulb? I rarely use my high beams as it is...
because the street lights give enough light. But the do become useful if you are in a poorly lit area. However the low-beam xenons do a great job already lighting up the road. I have rarely used my high-beams.
the high-beam is the same, except what happens with the low-beam xenon project is that the shield moves (that creats the cutoff you see, that doesnt allow the xenon light to blind oncoming traffic) which will take away the cut-off and allow the xenon light to project upwards acting as a high-beam.
