Sparco Shift Knob Installed. "I Like" (Borat Voice)
Got around to installing my Sparco Litium **** that I orderd last week. The feel is great, it complements my SS very well. Install was pretty straight forward, but I figured I would show a few pics to help others who might be interested, or at least to pass on the "mod bug".
Proceded to remove stock **** by removing the crimp clamp under the shift boot. I lowered the shaft all the way down because this **** did not sit as low as the stock one so I'm glad I had some slack to play with there. (Not an option if you have an OEM shifter, I have an AMS Short Shifter)
The next and probably the most important piece needed (for aesthetic value), so the shift boot doesn't end up looking like ***, I followed on the idea of a coke bottle neck from a fellow AW'er but tweaked it a bit.
I found a smaller plastic bottle, manufactured by a candy co. called Sips. The bottle is 1/2 the size of a coke bottle and the neck size was just perfect.
<img src="http://quattrofan.com//pics/Neck1.jpg">
Then I took off about 1/8" of material from top to bottom so that when I squeezed it with a clamp is secured the shift boot well. I also used a 2nd clamp under the plastic neck for extra support.
<img src="http://quattrofan.com//pics/Neck.jpg">
<img src="http://quattrofan.com//pics/SparcoInstall.jpg">
<img src="http://quattrofan.com//pics/SparcoInstall2.jpg">
I secured the shift know completely before finishing up with the boot.
Excuse the dust, but I was in hurry to install.
<img src="http://quattrofan.com//pics/Sparco3.jpg">
<img src="http://quattrofan.com//pics/Sparco.jpg">
<img src="http://quattrofan.com//pics/Sparco2.jpg">
I also had to sew the "mouth" of the boot just a little to make the opening smaller, that helped in keeping it in place to properly secure it to the bottle neck.
That is all.
That is all.
for a lexus truck but I cut, sanded, filled and then covered in leather to simulate the glove box finish.
ltooz_a6_a8_q7
14
04-12-2024 12:11 PM
ECS Tuning-Audi
Q5/SQ5 MKI (8R) Discussion
11
02-24-2023 12:58 AM
d0nut s4
02-11-2016 04:48 AM
ltooz_a6_a8_q7
12
11-29-2015 07:21 PM
kjmiles
09-04-2015 04:01 AM
