Stereo install 99% done....Only problem is it won't work! Who can help me analzye this? With pics!
Allright, here's the deal.
I have the stock non-bose system in my 2002.
I tapped into remote turn-on for the stock amp, as well as postive and negative wires going to stock sub.
I ran pos. and neg. wires to a line converter.
I grounded both line converter and amp to a good ground under the back seat, and grabbed power from the power distribution block (a 4 gauge wire that runs directly from the battery to behind the fuse block)
When i turn radio on, amp turns on (LED lights up) but i get NO sound.
Line converter has adjustable pots, but running them through their whole range doesn't change a thing.
It's a stereo amp (xtant 202m) which i'm bridging to mono to drive a single JLAudio 15W0.
I'm pretty sure my wire taps are allright, but how could i test them? would hooking up a multimeter to them and setting it to record AC voltage at least show me if there's a signal?
What would be YOUR next step in troubleshooting?
I appreciate any help!
Pic 1: Subwoofer
<img src="http://pictureposter.audiworld.com/28628/sub1.jpg">
Pic 2: Amp (w/out sub wires connected yet)
<img src="http://pictureposter.audiworld.com/28628/amp1.jpg">
Pic 1: Subwoofer
Re: well....
So you are getting no sound at all? From any of your speakers? I was thinking that maybe there was a prob with the amp sending the signal to the woofer but if your other speakers are hooked up to the head unit and you still can't hear anything, then I am out of ideas. Sorry Sohcrates!
sorry...all speakers work EXCEPT my new sub!
must have not been clear.
some people have suggested that i hook up my portable cd player to amp and see if it works..if so then i'll know if it's amp or wiring
i'll report back in a bit!
Update:
Plugged portable cd player in....amp and sub combo kicks out MUCHO bass...works great
Hooked multimeter up to output of line converter on AC Voltage...don't get a signal...so therefore is my problem.
The line converter i got from a Tweeter etc. and it has instructions which say to hook speaker wires (up to 55 watts) up to it, ground it, and then run RCA outs to your amplifier...so it HAS to be the right thing...no?
Sounds to me like my wire taps might not be good....but it's AWFUL to get back there and get at them!
Wonder how i can test them....
Oh yeah, and with portable cd player hooked up, and bass going, the trunk rattles like there's NO TOMORROW! What gives? i thought audi's might be built tighter than that! sounds like it's rattling right underneat the trunk...
r u sure you need a ground for the line converter?
my audiolink ii said to NOT ground it. It said that only with certain amps would you need a ground. I do not know if that may be your case...but my converter is not grounded. I will check the wattage rating and get back to you.
Patrick
Patrick
It works! By god it works!
Thanks everyone.
I re-tapped the wires for +/- to the sub and now it works great!
(and i removed the ground from the line converter)
Thanks everyone!
Thanks everyone!
