Strange Problems with Audi
Recently bought on 2003 3.0 Audi A4 quattro (salvaged) with some strange problems attached to it.
When first starting the car, i put the car on drive or reverse... but it does not drive or reverse until I wait half a minute.
One time the car was left idling, and the engine cut off by itself.
Also, only one time, I was pulling out of a parking lot, and while on drive... the engine reved itself and started reversing while on drive!
The engine and transmission itself are very sound (exceptional actually)... I think it is an electronic problem... the Audi is just so complicated... love driving it though.
Anyone with similar problems? Something I could specifically direct a autoshop to look at? or even fix myself maybe??
Also, drop the transmission pan and change the ATF filter and all ATF fluid. This is a fairly involved process. The fluid alone costs $100. The filter and gasket cost about $30. Labor for this job would be one or two hours.
Your symptoms could be caused just by low tranny fluid.
The car was in a front end collision, no flooding involved to my knowledge.
Transmission fluid is new, saw them go through the process
Ill check out the tranny computer and do a vag-com.
Anything else?
Also, when they were fixing up the Audi, they had to replace the engine head (original one was too expensive to repair)... this is when the specialist had the most problems trying to get the electronics to properly function (AWD, gear shifting, etc) with the new engine
Anything else?
I would expect VAG-COM to show some implausible signals received by either the ECU or tranny controller.
It's possible that you have a failing transmission, but mine started shifting slowly and slipping like mad between gear shifts. Another possibility would be some bad solenoids in the valve body.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
08-28-2015 11:43 AM
ECS Tuning-Audi
S4 (B8 Platform) Discussion
08-27-2015 01:31 PM
ECS Tuning-Audi
08-27-2015 01:27 PM
