Stupid tie rod end 22mm nut is stucked....
I am in the process of changing the tie rod..removed the 2 front bolts, but the adjusting nut is not turning at all....used pentrating lub for 3 hours already...any suggestons anyone??
Thanks..
Jack 99.5
Thanks..
Jack 99.5
remove the inner and outter tie rod as one pice
the put the inner tie rod in a vice and use a torch to heat the bolt up then use two box wreches against each other.
this is by far the fastest way to do it if they are really seized up. takes about two minutes to removce the inner tie rod because its always covered by the tie rod boot.
uble1234
14
10-23-2020 08:07 PM
PainDOC
09-26-2015 07:32 AM
havocgb
09-25-2015 04:50 PM
