Symphony II Stereo Layout....
This comes from the CDROM Manual. I suggest getting your own if you really need to work on something. Rawfonics had asked to post more, so I figure I'd share with you all.
The front speakers are powered by the stereo and the rear speakers are powered by the amp.
<img src="http://www.leitao.com/a4/manual/Amp-1.gif">
I believe this is the BOSE Amp.
<img src="http://www.leitao.com/a4/manual/Stereo.gif">
This is the diagram of the speaker layout throughout the car.
1. CD Changer (optional)
2. Center Speaker
3. Radio
4. "Amplifier for rear loudspeakers or BOSE power amplifier (only with "BOSE sound system")"
5. Subwoofer
6. Control module for antenna selection
7. Rear treble loudspeaker
8. Rear bass/mid-range loudspeaker
9. Front treble loudspeaker
10. Front bass/mid-range loudspeaker
<img src="http://www.leitao.com/a4/manual/Stereo2.gif">
Terminal Assignments
1. Rear window antennas
2. Control unit for antenna selection
3. Front bass/mid-range loudspeaker
4. Front treble loudspeaker
5. Rear bass/mid-range loudspeaker
6. Rear treble loudspeaker
7. Amplifier for the rear loudspeakers
8. Bass loudspeaker (subwoofer)
9. Center loudspeaker
10. CD changer
The avant layout is a just a little different because they mount the amp and sub in different places.
This info comes from the Repair Manual CDROM that <a href="http://www.bentleypublishers.com/">www.bentleypublishers.com</a> sells.
2. Center Speaker
3. Radio
5. Subwoofer
10. CD changer
<a href="http://www.leitao.com/a4/manual/ampwiring.jpg">Image is too big to post here.</a> Open it in a new window.
R - Radio
R12 - Amplifier
R15 - Bass speaker, left rear
R17 - Bass speaker, right rear
R34 - Left Rear Midrange Speaker
R35 - Right Rear Midrange Speaker
R100 - Bass loudspeaker
T20b - 20-Pin Connector, black, door B-pillar, left
T20c - 20-Pin Connector, black, door B-pillar, right
T20d - 20-Pin Connector, black, radio connector I
346 - Ground connection (Audio), in instrument panel
wiring harness
R - Radio
R12 - Amplifier
wiring harness
xkahn
02-08-2018 10:43 AM
changareth
9
09-13-2015 10:58 AM
