Is there an easy way to move the rear sub-frame?
I'm trying to center the rear sub-frame to fix a toe-in issue. I loosened all four of the 18mm bolts but I can't seem to budge/slide it. Do I have to compress the springs to take some pressure off?
Regardless, the toe and camber are adjustable on the rear, what is the problem you are having with the toe settings?
The left is at .39 degrees and the right is at .11. The left side's adjuster bolt is maxed out (low as it will go) so I cannot balance the two sides, or get them closer to 0. While under the vehicle I noticed that the rear sub-frame (drivers side) is shifted to the front of the car, while the passengers side (front mount) is slightly to the right on the large silver washers. Causing the rear thrust angle to point slightly to the right front of the car. So, using the right rear mount as a pivot point I want to pull the drivers side back, to bring the lower control arm back and out a bit. That should give me some added range for adjusting the toe to about .05 degrees per side. The shop that did the alignment would not touch the rear sub-frame, so it's up to me to get it centered. I would have just taken the car somewhere else, but I signed up for that life time alignment deal. Once I get things somewhat centered I'm going to take it back for a another alignment(free).
Well, I guess I'm off to AutoZone to rent a spring compressor (for the 3rd time). Like you said, there is only a small range that the sub-frame will move, but I think it should be enough. Thanks.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
22
05-11-2024 04:38 PM
Audi A4 2002 S4 6spd 98k
rsixxer23
01-06-2016 03:25 AM
S4intheOC
09-08-2015 12:12 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
