Is there an easy way to remove the lower grill without taking off the front end?
i think so....
i did it on my cab, i'm guessing the sedan is similar.
you'll need to remove the top grill, mine had three torx screws i had to remove. by doing that i was able to reach down infront of the radiator to the back of the lower grill. the grill just snaps in with a number of plastic clips. you will need to push down on the clips to release... it'll take a little fidgeting and feeling around. once you get one unclipped, the rest is easy and the grill pops out, just be gentle and take your time. again, i did this on a cab... it took about five minutes to do.
if it's not loose to begin with then you'll need to push the sides in towards the center of the car
as you pull towards you. I don't recall the removal method changing for any of the Model Years. Just give it a good tug. Make sure you're grabbing on to the outside fins when you pull.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
22
05-11-2024 04:38 PM
Mark VII
14
09-26-2023 10:11 AM
N'Syncro
33
02-16-2020 03:12 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
