Is there an RJ45 connector with phone connections in the B6 like it was in the B5?
In my last A4 (B5) there was an RJ45 connector under the center arm rest that had all the connections for phone kit pre wired. Is there a similar connector for the B6?
This made it really easy to install a phone kit.
If there's no connector, does some have a diagram of the best place to get my 12v, switched 12V, and ground? Also, what do you do to avoid getting the annoying humm with the alternator?
With my old car being prewired I didn't have to worry about this.
just get one for my wifes 1.8t. And just to clarify, the Ericsson kit is Blue tooth as well. It also has a connector to use the car speakers (sold separate). I just want to do a clean install with no issues.
similar to the one in the Parrot kit. It's just a generic speaker wiring harness. I'm asking because I do have Bose, and I don't want to spend $50 on this adapter if I can't use it.
You can use the steering wheel buttons in a 2004+ vehicle:
You can install in any Symphony or RSN-E 2004+ vehicle using a Parrot bluetooth kit and steering wheel controller apparently - see:
https://forums.audiworld.com/a4b7/msgs/57043.phtml
