throttle position sensor, is there an aftermarket option????
#11
I did not post the year and miles but this is the A4 B6 forum right?
BTW it is an 03 1.8TQ 106K.
Up until this point I have never had a code I could not trouble shoot and figure it out. I have not spent any excess money trying to fix this. The vac leaks I did fix need to be repaired anyway.
The issue is not the main reason I am considering trading it in. I said that because I have never owned an Audi that one thing after another goes out. It is like every time I fix something on this car something else goes out or breaks, and more than a few times it is a part that has been replaced not that long ago. Which a lot of times the part is under warranty but still me having to take the time to do the job a second time is a pain in the @$$.
Anyway I am not here to debate this with you, I am wanting to know if an aftermarket TPS sensor exist or do I have to buy a whole throttle body?
This has got to be the problem as I have tested/checked everything else on the car that could cause this series of codes with the symptoms it is having.
#12
have you pulled the MAF sensor for a look-see?
Maybe clean it?<ul><li><a href="https://forums.audiworld.com/a4gen2/msgs/1055407.phtml">https://forums.audiworld.com/a4gen2/msgs/1055407.phtml</a</li></ul>
#15
it in a while but checked it and it looks good.
Once I replaced the MAF the idle car as it should. It is running worse now than when it went out.
#16
Maybe replace the K&N with the OEM paper filter, clean the MAF sensor, and see if this resolves the issue.
I run the AFE Pro Dry filter. Its built like a K&N, but uses no oil-<ul><li><a href="https://forums.audiworld.com/a4gen2/msgs/1098144.phtml">https://forums.audiworld.com/a4gen2/msgs/1098144.phtml</a</li></ul>
irelandbuyer
07-21-2019 01:54 PM
saifxnyc
9
11-30-2015 12:32 PM
Captain Rossness
Audi A3 / S3 / RS 3 MKII
26
09-24-2015 05:34 AM
