top of gauge cluster display is starting to flicker...usually seems to calm down after cooling
has anyone seen this happen before?
it's just the top few lines that are flickering.
i wonder if it's just a loose connection or a solder joint that needs redone...any ideas?
I've had the car for five years now and it has never happened before. The "OK" that displays on startup is dim and flickers.
Then the "CD1" for example will be slightly dim at the top of the number only. I searched the forums and can't find a cause either.
It goes away after a few minutes and after turning the radio off and back on.
http://www.audiusa.com/audi/us/en2/forms/customer_relations.htx
they said that they are tracking the issue and that the instrument cluster is a recalled item in europe.
I'm thinking you'll likely get one tomorrow. Be courteous and understanding, but at the same time express that you don't expect this of an Audi.
PoisonBeef
09-04-2015 05:29 AM
