Turbo Inlet Pipe BT...
Old 04-21-2008, 08:05 AM
quattrothatcould's Avatar
Default Turbo Inlet Pipe BT...
What would be the benefit of using a solid TIP (JJ Tip, O.cT) vs a silicone TIP (Forge, Samco, etc)? I've noticed in my research that the solid TIP's are not as popular, but seem to be found on the cars pushing higher numbers out of a K04. I'm hoping someone could explain some pro's/con's of each type and post personal experience with the one you have/had. TIA
Old 04-21-2008, 08:39 AM
nanotech's Avatar
Default I think it's pretty simple, solid doesn't collapse at all
I doubt there's a significant difference though, between the silicone and solid TIPs.
Installing the solid pipe is harder.
Old 04-21-2008, 09:17 AM
Member
QuattroFan02's Avatar
Default I have the APR Tip which is silicone but spring-wound to add stiffness and prevent it from
collapsing. Works for me.
Old 04-21-2008, 10:02 AM
tuneda4's Avatar
Default have you ever seen the spring? its like dental floss lol
i purchased the apr before i had the neuspeed because of that extra spring crap. i would have kept it but apr sent me the wrong one and on top of that i needed the neuspeed to run the gtrs. i was bored and looked into the who apr spring thing and its just marketing crap
Old 04-21-2008, 10:05 AM
tuneda4's Avatar
solid = money. you should be fine with the neuspeed or the apr one
Old 04-21-2008, 12:00 PM
AudiWorld Expert
MikTip's Avatar
Default Over time...
its reported the Silicone gets flimsy from the oil from the crankcase recirc fumes. I've never experienced this, but have read a couple post say they have...
Tough to say how log it takes for the blow-by oil to effect the silicone hose, enough to allow it to deform under boost.
The Solid TIP's wont suffer from this.
Old 04-21-2008, 12:14 PM
AudiWorld Expert
MikTip's Avatar
Default IMO, the better buy is the Forge...
<center><img src="http://pictureposter.audiworld.com/6607/forge.jpg"></center><p>
as I've owned all 3. The First one I bought was the APR. The Forge, which only cost $20 more than the APR, but didnt need a "T" and came with clamps, was bigger. The Forge also fit without any problems, on my 2004.
The Neuspeed costs over $100 more than the Forge, and the 2004 Neuspeed even more, because of an adapter hose needed. The Forge did not need the hose.
I currently have the Neuspeed, as I bought is second hand for a good price.
To date, the Forge, I still like better.
Only down side, is the Forge is for K03/K04 only.
The Neuspeed has an adapter plate($50) from Neuspeed, which allows it to work on larger turbo's .
If your running a K03/K04, get the Forge.
Big Turbo, you have to get the Neuspeed.
Old 04-21-2008, 12:15 PM
AudiWorld Expert
MikTip's Avatar
I heard its wound into the silicone, and can't be seen...
Old 04-21-2008, 12:18 PM
AudiWorld Expert
MikTip's Avatar
Default Neuspeed...
<center><img src="http://pictureposter.audiworld.com/6607/mods.1.jpg"></center><p>
I got it back when I bought my AFE Dry filter...
It did not fit as well as the Forge...
Both are made by Samco.
Old 04-21-2008, 12:22 PM
AudiWorld Expert
MikTip's Avatar
Default The APR...
<center><img src="http://pictureposter.audiworld.com/6607/aprtip.jpg"></center><p>
never took it out of the bag...
Quick Reply: Turbo Inlet Pipe BT...
