Ultrasuede trim
#31
I just took a look at my car, and found a screw on the end of the trim on the passenger side. There's a panel on the side of the dash, just like the fuse panel. Remove it and take a look at the side of the dash, just above the trim. You'll see a round hole in the dash structure. inside that hole there is a screw. That screw holds the right side of the dash trim in place. Then take a look at the left side, just to the right of the steering column. There should be another screw just like the one on the switch piece you just removed. The pleather column trim might be hiding it, so you have to look closely.
Once those are removed, I think it's just the pronges like the door. I took flashlight and pushed on the trim in a bunch of different places, and it all flexes like there's not much holding it in. Try removing these two screws, then starting at the right side and working your way left. Let me know how it goes.
#32
The foamy-trim piece above the card/cup holder needs to be pryed out and there are 2 more screws behind it. Luckily i found this out before i snapped em off. So there are 4 screws holding on the trim piece itself and 3 more holding on the driver side knee bolster. Thanks for all your help.
