Update 2: Sprint Booster + K04 + Lemmiwinks
#11
But they used Unitronic's software. It looks very similar, if not the same, to Lemmiwinks.
<a href="https://forums.audiworld.com/a4gen2/msgs/1089127.phtml" target="_blank">Click</a>
#15
The reason the different settings used by the author of the linked thread didn't change the idle speed, is because the adaptation channels are locked and can't be changed on later m.y. ECUs. The alleged changes to throttle response described, are IMO, a placebo effect at best. There is no documented correlation of function/setting for channel 01 associated with the claimed effects on throttle response or throttle pedal to throttle valve rate of opening speed regardless.
geter
09-29-2015 01:39 AM
