upper control arms bolt
<center><img src="http://pictureposter.audiworld.com/69642/picture_001.jpg"></center><p>Need some help removing the this bolt from the upper control arms on my car. Is there any easy way the bolt is not moving at all. used hammer and lost of WD40 and nothing.
Thanks
haime
Thanks
haime
the threaded side. The two pins on the control arms are contored so that you cant pull them out of the knuckle until you pull that bolt out.
Just keep working it, it'll come out.
and still not moving! i bit the **** out of the bolt! that the treads are too "fat" now and i'll have to cut the ends of and still not moving!
can i get PB blaster and advance auto parts?
thanks
haime
thanks
haime
and the bolt has not moved!!
zero same place?
how much should i raise the rotors? how much time with the torch?
is it supposed to be this hard?
thanks
haime
zero same place?
thanks
haime
