Vag com says knock sensor...
I've got a 02 A4 1.8 and the engine sounds like the timings off but no loss of power. bought the car recently and its always sounded this way so i picked up a vag-com. What is the prognosis? and what do i do from here?
VAG-COM Version: Release 409.1-S
Control Module Part Number: 8E0 909 518 E
Component and/or Version: 1.8L R4/5VT G 0001
Software Coding: 0016701
Work Shop Code: WSC 00999
5 Faults Found:
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 002 - Lower Limit Exceeded
16840 - EVAP System: Very Small Leak Detected
P0456 - 002 - Lower Limit Exceeded
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 008 - Implausible Signal - Intermittent
16712 - Knock Sensor 1 (G61): Signal too High
P0328 - 001 - Upper Limit Exceeded - Intermittent
16395 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
P0011 - 002 - Lower Limit Exceeded - Intermittent
5 Faults Found:
Clear and see what comes back. All of those are intermittent so if they have never been cleared, the error may have happened years ago.
One a separate subject, what noise is it making and where is it from?
Es4go
12-07-2006 04:36 AM
justwentgerman212
10-17-2004 12:19 PM
the senator
11
12-24-2003 11:47 AM
