vagcom results, if only it were something easy lol
VCDS Version: Release 11.11.2
Data version: 20120126
Thursday,08,March,2012,20:04:05:52370
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAULT68E82A065020 Mileage: 184580km/114692miles
Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 8E0 909 559 D HW: 8E0 909 059
Component: 3.0L V6/5V G 0002
Coding: 0016751
Shop #: WSC 63351 000 00000
VCID: 367DEAE9425C5C3
9 Faults Found:
17548 - Oxygen (Lambda) Sensor; B2 S2
P1140 - 008 - Internal Resistance too High - MIL ON
17831 - Secondary Air Injection System; Bank 1
P1423 - 002 - Insufficient Flow - MIL ON
17819 - Secondary Air Injection System; Bank 2
P1411 - 002 - Insufficient Flow - MIL ON
16805 - Warm Up Catalyst; Bank 1
P0421 - 001 - Efficiency Below Threshold - MIL ON
16815 - Warm Up Catalyst; Bank 2
P0431 - 001 - Efficiency Below Threshold - MIL ON
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - - Intermittent
16685 - Cylinder 1
P0301 - 008 - Misfire Detected - Intermittent
16688 - Cylinder 4
P0304 - 008 - Misfire Detected - Intermittent
16690 - Cylinder 6
P0306 - 008 - Misfire Detected - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8E0 927 156 Q
Component: AG5 01V 3.0l5V USA 1213
Coding: 0001002
Shop #: WSC 08057 444 63493
VCID: 3C69F8C17C70863
No fault code found.
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04497
Shop #: WSC 06435
VCID: 265D3AA9C2FC2C3
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 G
Component: A4 Klimaautomat 0711
Coding: 00000
Shop #: WSC 63351
VCID: 255F3DA5BFFA27B
2 Faults Found:
01592 - Air Quality Sensor (G238)
30-00 - Open or Short to Plus
00819 - High Pressure Sensor (G65)
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul USA 0517
Coding: 00013
Shop #: WSC 08307
VCID: 357FEDE50F5A57B
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 A
Component: Airbag 8.4E 3000
Coding: 0010607
VCID: 357FEDE55F5A57B
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 01141
Shop #: WSC 63351
VCID: 3C69F8C12C70863
2 Faults Found:
01332 - Door Control Module; Passenger Side (J387)
49-10 - No Communications - Intermittent
01330 - Central Control Module for Central Convenience (J393)
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 H
Component: KOMBI+WEGFAHRS. RB4 D21
Coding: 03200
Shop #: WSC 40807
VCID: 2E4DC289EA0C643
WAULT68E82A065020 AUZ6Z0A0164923
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0201
Coding: 00002
Shop #: WSC 63351
VCID: F1F799F5BBB2BBB
4 Faults Found:
01331 - Door Control Module; Driver Side (J386)
79-00 - Please Check Fault Codes
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0504
Coding: 00001
Shop #: WSC 00000
VCID: EBCB8B9D999E51B
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 T
Component: Komfortgerát T5B 0616
Coding: 11788
Shop #: WSC 63351
VCID: 429586394E94F03
Subsystem 1 - Part No: 8E1959801
Component: Tġrsteuer.FS BRM 4.22
Subsystem 2 - Part No: 8E1959802E
Component: Tġrsteuer.BF BRM 4.22
Subsystem 3 - Part No: 8E0959801A
Component: Tġrsteuer.HL BRM 4.10
Subsystem 4 - Part No: 8E0959802A
Component: Tġrsteuer.HR BRM 4.10
16 Faults Found:
37-00 - Faulty
01616 - Signal Wire to Interior Monitor
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
01705 - Selection Switch for Mirror-Adjust (E48)
27-00 - Implausible Signal
01560 - Passenger Door
59-10 - Can't Unlock - Intermittent
01333 - Door Control Module; Rear Left (J388)
01561 - Left Rear Door
01334 - Door Control Module; Rear Right (J389)
01562 - Right Rear Door
Address 55: Xenon Range Labels: 4B0-907-357-DYN.lbl
Part No: 4B0 907 357 C
Component: dynamische LWR D06
Coding: 00060
Shop #: WSC 63351
VCID: 28413491C8E83A3
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 A
Component: symphony II NP2 0011
Coding: 00201
Shop #: WSC 00000
1 Fault Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
36-00 - Open Circuit
End ---------------------------------------------------------------------
69 75 76 77
Coding: 0016751
9 Faults Found:
16685 - Cylinder 1
16688 - Cylinder 4
16690 - Cylinder 6
Coding: 0001002
Coding: 04497
Shop #: WSC 06435
Coding: 00000
Shop #: WSC 63351
2 Faults Found:
Coding: 00013
Shop #: WSC 08307
Coding: 0010607
Coding: 01141
Shop #: WSC 63351
2 Faults Found:
Coding: 03200
Shop #: WSC 40807
Coding: 00002
Shop #: WSC 63351
4 Faults Found:
Coding: 00001
Shop #: WSC 00000
Coding: 11788
Shop #: WSC 63351
16 Faults Found:
37-00 - Faulty
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
Coding: 00060
Shop #: WSC 63351
Coding: 00201
Shop #: WSC 00000
1 Fault Found:
Try clearing the code and scan it a week later to see which comes back. So far looks like you need new cats (common for the 3.0) new 02 sensor on driver side after the cat
New coil pack on the cylinders that are misfiring + plugs
Check you sai pump if it's working or not. Of it works then check your vacuum lines of it doesn't you need a new pump.
Definitely clear and see what comes back. Sometimes one issue will cause the rest to happen. Don't jump to swapping a bunch of parts. It may be a simple vacuum leak.
AudiQmann
11-01-2008 03:30 PM
Eurostile
VAG-COM Discussion
11-08-2005 06:11 PM
