Valve Cover Gasket
I recently took my 2002 A4 1.8T quattro in to get my coil recall and they informed me that there was a major oil leak at valve cover gaskets. They said it looked like someone drilled into the valve cover/gasket? They told me that it would be $597 to fix and that it would take about 5 hours to do. I thought this seemed a little steep. What do you guys think I should do?
Not if they are replacing the valve cover itself as well. However, I would ask to see the "hole that was drilled" before I authorized them to replace the cover itself.
Also, if they're replacing the VCG, make sure they replace the cam chain tensioner gasket that is a common site for leakage on the back of the valve cover. I can't imagine it taking five hours though, it should only take an hour or two tops...unless they're counting the time for your engine to cool so they can work on it.
Audi Logic
Audi 100 / A6 (C4 Platform)
07-15-2005 01:51 AM
Crisqo09 T.O.
12-13-2002 08:24 PM
Skywalker
07-08-2000 07:20 PM
