Weird thing happenin with my driver window...
intermittently, the window won't close with the one touch button. It closes all the way, then opens back up 3-4 inches. Interestingly, once this happened for an hour of so and the key feature to open up all of the windows didn't work either. I pulled out the fuse which looks ok. It has happened only twice so far, for a few hours each time...weird, huh.
It seemed to happen if I was parked for a while with that window down and then attempt to roll it back up when I drive away. Bizarre behavior.
I'm expecting it soon as the weather is warming up. also get a steering wheel creak in hot weather.
I ran into this same problem, both on my C230 and now my A4. Luckily MB roadside taught me how to reset the switch. Basically hold the switch in the close position as far back as it goes and do that for about 5-10 seconds. That should do it. What you describe is what happens when our power windows are configured to vent positioning which is adjustable.
You're lucky this happened to you with your windows only staying rolled down a couple inches. I had this problem when my windows got stuck all the way down on a cold night...
bilbo6209
09-09-2015 01:28 PM
raiderrider
12
09-08-2015 05:46 AM
jjcuff1
A6 (C7 Platform) Discussion
09-08-2015 12:02 AM
