What is the difference between QUAttro and 4X4?
Also, there was a discussion earlier that the ESP light won't come on..i had BMW and i have to turn off ASC in order to move forward in the snow otherwise power would be cut..
With Audi, is it necessary to turn off ESP?
Thanks
Thanks
4x4 is full time 4wd. 25% power to each wheel all the time. quattro is AWD (all wheel drive) power can be shifted, cut, and applied to differnt wheels baised on traction via 3 differentails. ESP will do exactly what it sez it will do, it will keep the car stable and in a striaght line (or matain a turn). The only reason you would need to take it off is if you are stuck in deep snow and need to spin the wheels (or if yah wana do some slides
) BMW's are mostly RWD, and RWD will spin alot in the snow, hence the need to turn ASC off so it doesnt cut the throtle out on you when your trying to move.
don't have a front/back differential which is why vehicles like the Ford Explorer shouldn't use 4 wheel drive on dry pavement.
Quattro is Audi's trademark for all wheel drive- Torsen in all the A and S models, and Haldex in the TT. And Torsen center differentials are not unique to Audi - Toyota uses one in the '03 4Runner.
