what is the normal operating coolant temp on a A4 1.8T
My car idles high and my coolant temp is at 105* trying to isolate the problem. i also get
Control Module Part Number: 8E0 909 518 AK
Component and/or Version: 1.8L R4/5VT G 0005
Software Coding: 0016751
Work Shop Code: WSC 08376
1 Fault Found:
17519 - Oxygen (Lambda) Sensor Regulation: Bank 1: System too Lean
P1111 - 002 - Lower Limit Exceeded
Idle RPM is 1050RPM
Coolant temp at Idle is 101-105*
lambda is at 25%
MAF 3.6-3.8 G/s
Ign timing is at 5.3*
Lambda reads 1.039
1 Fault Found:
Idle RPM is 1050RPM
lambda is at 25%
MAF 3.6-3.8 G/s
Lambda reads 1.039
TVonaStone
Audi 100 / A6 (C4 Platform)
04-08-2015 06:38 AM
