WHAT IS THIS PART?
My engine light came on the other day and its throwing the code P0456 Evap leak. When I looked under the hood, I found a big hole in the under side of this plastic part. Can anyone identify what this part is called? Its the one circled in red.
![](http://i55.tinypic.com/10iifrm.jpg)
Depends on how bad the leak is. If it a small leak, you will loose a little hp. If it is large, you will get the no start. easy replacement. Pretty sure the link below is the part.
http://www.ecstuning.com/Audi-B6_A4-...h/Check_Valve/
Hey guys, I got the new check valve from ecstuning.com and installed it today. With the corroded valve, my car seemed real slow and sluggish. I probably got an increase of 20+ HP just from this new $15 part. Its back to performing like when I first got it. I also installed the aero wiper blade upgrade kit from ecstuning. These wipers are way worth the money!
Had a similar problem and I came to find that additional valves were on their way too failing--in one case, the only thing keeping the valve in place was the tubing.
Rick 601
Audi 100 / A6 (C4 Platform)
09-04-2004 03:10 AM
soupnazi
12-19-2001 05:02 AM
