What synthetic oil for A4 3.0?
#13
Factory Fill is 0w30.
If you can't find 0w30 to use 5w30 or 5w40 - it does not state 0w40.
I couldn't find any 5w40, however.
Why did I think it said 0w40?![Confused](https://www.audiworld.com/forums/images/smilies/confused.gif)
And just to double check, it's 6.6 quarts needed for the oil/filter change?
Thanks..
Thanks..
#16
0W-40 tends to be the choice because of the better Euro spec'd oils offered in that grade (same with 0W-30). Most 5W-40's are not the premo oils.
The difference between the 0W-XX & 5W-XX is that one has a lower temp. pour point (winter grade) then the other. A 5W-40 will be fine as well. I'd still get the Motul Ester E-Tech 0W-40 (check out the standards/approvals) it's got them and goes beyond. The ester base is much better then the others. If you want a 5W-40, then get FUCHS ProS 5W-40. Or go with whatever makes you happy.
#18
I would like a 5w40, but I could not find that anywhere.
Where can I get the FUCHS ProS 5w40?
#20
Meaning, would I gain anything? I understand that a 0w will pour at like -65 degrees F, where as 5w and 10w are higher than that, so what is the difference? Will a 10w do better in the summer?? Should I stop being so paranoid about this?!
![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
