what would happen if i forgot to mix my coolant b4 i put it in
i put in the coolant then remembered that its not pre-mixed
so then i added water but what im saying is that it was already in the lines and now my car seems to idle kinda hard?
your car will run hotter if you have to much of the coolant and not enough water
but if there the same then after a couple drives it should all mix together regardless if you added them premixed or not. Car wont run any different except for the temp thing.
Get a mini-hygrometer.Wal*Mart has 'em, $2. Float 4/5 density ***** & you're good.Watch out for-
micro-bubbles that stick to the coloured *****. You might have to tap it to get those air bubbles off...like a doctor does before giving an injection. 4 ***** is about -25f, forget 50/50%, the hygrometer is more accurate and desireable measurement.
LaserSVT
64
01-19-2016 04:26 PM
