What's the difference between the different size sway bars? contd.
results, you should probably get both front and rear bars- H-Sport makes a front and rear set that are adjustable to optimize the balance of the car. I have just a rear bar right now, which helps reduce understeer, but to really tighten up the handling, a set of both bars is probably best.
I plan to upgrade to these myself.<ul><li><a href="http://www.pure-motorsport.com/products/description.php/II=587/CA=213/PA=7">H-Sport Sway Bars @ Pure MS</a></li></ul>
When comparing diameter, you have to also take into account whether the bars are hollow (H-sport) or solid (the others) and material.
1. H-SPORT: front and rear. $372.95. It certainly does the job. The question I have is whether doing the front and rear is overkill, when doing the rear eliminates understeer. I've driven a car with the sport suspension and H-sport bars. Two bars are no substitute for upgraded springs and shocks.
2. H& R: Rear only. $172.95. Actually you can now buy a front, but it is not necessary to eliminate understeer. Many of us bought it before the front was available. On the stiffest setting, it made the car perfectly neutral.
http://www.pure-motorsport.com/products/description.php/II=689/CA=213/PA=7
3. Neuspeed rear: $289.95. It also eliminates understeer. On the stiffest settting, you can actually make the car oversteer a little. The only downside is that Neuspeed recommends welding reinforcement brackets.
http://www.neuspeed.com/products/product_details.asp?app=14|AQ&type=2&ltype =ns_euro&p_id=1174
A much thicker rear sway to neutralize handling and a thicker front sway matched to reduce overall roll. cheers! Mike
I have the Neuspeed rear right now (with the stock sport suspension, at the moment) and it's great for reducing understeer- in fact, it does make the car oversteer a bit, but it doesn't provide the same nailed-down, precise feeling as a fully upgraded suspension (as you point out) or two bars- I've found that with just the rear bar, the rear takes a good set, but the front tends to roll and wander a bit, making for a less precise feeling than I'd like. That's why I personally am going from just the rear bar to front and rear. I enjoy the effect of the rear bar, but it produces some slightly odd behavior that makes the nose harder to place with accuracy.
