When in 1st/2nd gear (5-speed) and I move the shifter while in gear it makes a wired sound...normal?
I know between shifts you should not rest your hand on the shifter. But if you do in first or second and you were to pull the shifter a little away from the normal position it makes a slight mechanical hissing sound - and you can feel it in the shifter.
Is this normal? Why is this happening?
Clarence Willie Mays
09-06-2015 10:30 PM
