When I have 3 passangers in the car my airbag light comes on
you need to scan your airbag control module to find the root cause...
but there is a known problem with the driver's side thorax bag (in seat). It has to do with a bad connector.
TSB: 690506 - 11/17/05 - Air Bag System - Warning Lamp ON/Sporadic DTC's
Group: 69
Number: 05-06
Date: NOV. 17, 2005
Subject:
Airbag Lamp ON, Upper Limit of Side Airbag Exceeded
Model(s):
A4 2002 --> 2006 to VIN 6A072674
Cabriolet 2003 --> 2006
Supersedes T.B. Group 69 number 05-05 Dated Jun. 2, 2005 due to VIN information added to header for A4 Model.
Condition
Airbag warning lamp in Instrument Cluster is ON and the following sporadic DTC(s) are stored in DTC memory.
^ 01217 001 "Igniter for side airbag driver's side -N199- Upper limit exceeded"
^ 01218001 "Igniter for side airbag passenger side -N200- Upper limit exceeded"
May be caused by sporadic too high resistance in the connector between the airbag and seat harness.
Service
Prior to performing the following procedure:
WARNING When working on ANY airbag system
ALWAYS read and follow Repair Manual
WARNINGS, Precautions, Notes and Tips!
See Repair Manual, Repair Groups 69 and 72, for detailed information.
Group: 69
Number: 05-06
Date: NOV. 17, 2005
Subject:
Model(s):
Condition
Service
I had that problem.(and fixed)
It was a bad seat beal pretensioner for one of the rear seats. When your 3rd passenger buckles in, the computer checks that seatbelt and you get an airbag light. They replaced the seatbelt tensioner under warranty.
Jeff Lanzone
09-08-2015 04:00 AM
akitamike
09-05-2015 03:01 PM
