Why won't my OBD-II cable work?
When I go to run the "test" on COM1, it say's "Port Status: OK, Interface: Not found"
I've already made sure the port on the cable is set to COM1 and that the driver is up to date but it's not finding it.... argh!!
The computer is finding the USB Serial Port & says that the new hardware is ready to use so why the F is this thing not being found by the VAG-COM software??
otherwise the interface has no power, and will not be visible to the PC/VAG-COM during test.
I already had another one working from the same place but gave that one to my Dad.
I'm running XP & tried both version 409.1 & 704 but neither can find the cable when I so the test.
When I ran the test it said port status OK & interface found. Can't figure out why this one isn't doing the same?!
I helped a guy locally who had the same issue. Once connected to the car it worked fine. It was an eBay USB cable too.
the latest version of VAG-COM that will run using a non Ross-Tech interface cable is v409. The later versions require the hardware dongle of a genuine Ross-Tech interface cable to run full capability.
carl viking
40
07-12-2024 02:45 PM
ltooz_a6_a8_q7
14
04-12-2024 12:11 PM
xkahn
02-08-2018 10:43 AM
ltooz_a6_a8_q7
Q5/SQ5 MKI (8R) Discussion
12
11-29-2015 07:21 PM
shabz
A4 (B7 Platform) Discussion
09-05-2015 12:34 PM
