Will I see a difference between OE Conti's and Toyo Proxes 4?
#15
thanks again! =]
• Unidirectional tread pattern with V-shaped main grooves
- excellent resistance to aquaplaning.
• Rigid shoulder rib pattern
- excellent dry handling/resists irregular wear,
- lower noise levels even in later tire life.
• New silica compound
- rigid tread hardness creates excellent dry handling characteristics,
- silica compound minimizes heat build-up,
- higher wet-traction coefficient achieves excellent wet handling.
• Ultra high molecular polymer
- excellent wear resistance.
• Spiral wound edge and cap ply with jointless construction
- excellent high speed durability and precise uniformity.
• Wide high-tensile steel belts
- excellent handling & high speed endurance.
• High-modulus rayon (or polyester) casing
- precise steering response and excellent traction.
• Rim protector
- protection of the rim flange from scratches and abrasion.
• High-modulus bead apex rubber
- precise handling.
i esp. like the last 2 points.. that's jus awesome!
mm.. well, your help is definitely appreciated and noted!
thanks again!
lean back~
• Rim protector
- precise handling.
thanks again!
lean back~
Audi Other FS: 2007 Audi RS4 black/black CCW
ilikeit
01-09-2016 09:24 AM
rayh4444
09-11-2015 11:30 AM
