Window problems
I recently had issue of radio not working and Windows not working. I read it was drivers door harness. Now the radio was a different problem but I did replace the drivers door harness and it kind of fixed the problem(I also replaced master switch). But not my drivers side windows go up and down. But the passenger side windows only go up. From the master switch. They do go down and up from their own individual switches. But only up from master.
Any help appreciated thanks in advance.
It is common for the DS harness to get brittle and break some wires.
Sounds like a break from the DS switch to the PS switch.
I think the DS signal passes through the PS switch.
you'll need to check for continuity and maybe jumper it.
The DS passenger switch might have a break right there at the switch....or inside the harness as it goes from the DS door to the body..that's where they break iside that rubber boot.
when I redid that harness, i spliced into that section with thicker wires and created a loop of it inside the door that would spring and pull the wire in and out of the boot, rather than actually bend the wire inside the boot....
polishadonis
08-21-2006 05:13 PM
skjolden
10
08-10-2006 01:37 PM
pete1033
Audi 100 / A6 (C4 Platform)
06-15-2005 11:19 AM
