Wipers stop in up position
All of a sudden my wipers stop in the up position. I have also noticed they run slower than they had previously.
I believe this started a few weeks ago when I got water in the floor pan on the driver's side. I have a new Central Electronics Control module but haven't installed it yet as I am still learning how to use the VCDS system.
Is this yet another symptom of a bad Central module or something else I should be looking at?
Audi Wiper
good luck if that made sense!
Windshield Wipers Stop in Up Position when turned off
The problem is most likely the wiper transmission (wiper motor). There is a catch on the trasmission that when it is returning to the down position to stop, one of the gears on the bottom hits that catch allowing it to stop in the down position. Most of the time you can simply hit that catch with a screw driver and hammer pushing it forward toward the gear until it is close enough to hit that gear, and that will solve your problem. Just make sure not to hit it to hard, because if you break that off, you are about to replace the whole thing. Ton of videos on youtube showing how to fix it.
lashb1
10-17-2009 05:47 PM
daiva
01-18-2006 09:46 AM
ej99a4
12-16-2002 10:13 AM
